Linear Pattern from sketch & Projecting to surface
- Mute
- Permalink
- Report
Hi all,
I'm raltively new to F360 and I've reached my first speed-bump. Help me out here...
I need to mill a decorative pattern on a piece of wood trim that will be attached to the facade of a column. The pattern looks like this:
I have created a sketch of one section of it in Fusion, but I can't seem to figure out how to turn it into a pattern.
That's my first problem.
Then, I'd like to project that pattern to create a CAM toolpath to use a 1/8" ball end mill to project on the surface of the wood trim and carve out the design. I thnik I figured out this second problem by using a 3D project toolpath, correct? Just how to correctly orient the pattern onto the surface of the wood trim.
This is the correct profile of the trim piece. I used Fusion to create the profile toolpath and cut it out to produce a jig to make the knife.
So first thing's first. How do I repeat this pattern in a linear direction from this sketch?
