line drawn at origin fully constrained, no icon
kmanuele
Message 1 of 9
kmanuele
Create a new sketch, draw a line starting at the origin. It becomes fully constrained, and I can't move it. I can shorten it via dimensions.
Fought with this for a while then found that it has a coincidence constraint whose icon is not shown in the browser -- only in the right click menu when editing the sketch.
Lesson? Don't use origin as an origin?
K
Replies (8)
Message 2 of 9
jhackney1972
Your model should be related to the Origin, either directly to it or dimensioned and constrained to it.  As you can see in the animated GIF there is not issue with a line to the origin and then moving it.  At the end I add a horizontal sketch constraint to the line and still and grab the end and move it.
John Hackney, Retired
Message 3 of 9
kmanuele
Not sure what you are doing that is different than me.
If I create a new design, create a sketch on one of the planes, draw one or more lines from the origin. The coincident constraints are not shown on the screen, and I can't move either line without deleting the coincident constraint in the context menu.
I've attached a simple file. Can you move those lines without deleting the (not shown) constraint?
K
Message 4 of 9
jeff_strater
You answered it yourself:  " It becomes fully constrained, and I can't move it. I can shorten it via dimensions."
The fact that you can shorten it with dimensions is what is preventing the entire sketch from being constrained.  The line is constrained if it starts at the origin and is horizontal or vertical, but the other endpoint of the line is not constrained, which is why you can affect it with a dimension.  Add that dimension, and the sketch is fully constrained.
Jeff Strater
Engineering Director
Message 5 of 9
jeffescott
Fusion adds constraints when you click on certain things.  Not so with other things you just have to get used to it.
Usually speeds things up, but it can get confusing at times
Message 6 of 9
kmanuele
I was simply trying to move (off the origin) a line that had no apparent (visible) constraints, even after removing any visible constraints from those fully constrained black lines.
It seems that for sketch items originating (or terminating) at the origin, the coincident constraint does not show up on the screen when hovering. It only shows up in the context menu. I eventually realized this.
It seems that the origin has special properties here (what happened to relativity ?? 🤔). Draw a line to the origin and extend it beyond. You can move the line but can't shift its orientation away from the origin (like a black hole 😃), and you can't delete the coincident constraint.
Also, during this I found that a line drawn on axis to the origin (rather than vice-versa) does not show a horiz/vert constraint except in the context menu.
Thanks for the responses. Please take mine as good-natured dialog, trying to learn.
K
Message 7 of 9
jhackney1972
If you have a line sketched from the Origin, you can easily find and delete the Coincident constraint if you select the line, near the origin end, right click and select Delete Constraint from the context menu.
Message 8 of 9
TrippyLighting
Not quite. What I'll write is not a hard rule as there are always exceptions that yields another method, however any sketch should reference either the sketch origin or geometry projected into the sketch form other sketches, or edges of 3D geometry.
If you don't want to constrain a particular sketch element to the origin, then don't start at the origin as it is clunky to remove, as you have discovered.
Message 9 of 9
kmanuele
Agree, designs (sketches) should have a reference point.  I just didn't expect this behavior from Fusion
thanks
K
