Limiting a Pattern
Limiting a Pattern
Limiting a Pattern
I'm new to Fusion 360 ( and CAD as a whole) and could use a little advice on a current project of mine. The first pattern you see here I would like to cut off (or stop) once certain shapes hit the inner most constructed circle, but I'm not sure how to do it. I suppressed some off the pattern when I created it, but as you can see some parts are half in half out. Aesthetically I'm ok with this occurring with some of the shapes, but I will be adding more circular patterns radiating off this center one so I need to clean this up to move on. Thoughts? Screen Shot 2017-12-11 at 9.04.55 PM.png
Phil.E
Hi, welcome to the Fusion 360 community.
Have you tried using Trim to trim the lines outside the circle? That should do the trick.
Please let me know if you have more questions.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Your question got successfully answered? Then just click on the 'Mark as solution' button.
Let us know how we did on Trustpilot
Thanks so much Phil that totally did the trick.
