Message 1 of 20
Lens Hood - Ridges on the inside
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I want to create a parametric lens hood design. It is basically a tube so should be simple. I am splitting the tube into three elements. First is the connecting section. This is simple. Then there is the middle section. This is a section that is just a tube. I will hopefully be able to add parameters for its length and diameter. All simple stuff. Where I am struggling is I want to add a ridged surface on the inside to prevent light reflections. Traditionally this is a series of ridges running around the inside of the tube. What is the best way of achieving this so whatever the height and diameter set in the parameters, the ridges remain consistent.,
