Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Learning sculpt environment. Bridging problem.
1 REPLY 1
dkampWQTNE
337 Views, 1 Reply
Learning the sculpt environment for the first time and I have used bridge a couple of times but with the example below I don't have a clue what went wrong. Have tried several times with similar results.  Any help would be most appreciated.
1 REPLY 1
mavigogun
in reply to: dkampWQTNE
Are some of those Edges Creased?   Creases can make Bridge this sort of unhappy- as can Symetry.  If so, consider removing the Creases or Symetry, Bridge, and then re-apply as required.
