Layout Grid changed after update?
O.Tan
Advisor Advisor
O.Tan
Can anyone confirm with me if layout grid function is changed after the update? Cause previously, when I edit a sketch, by default the layout grid will be turned on. Now I have to manually turn it on.
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
Maowen_Zhang
@O.Tan, you're correct. In current latest update (2.0.1517), if layout grid is truned off, then need to trun it on manually when you enter sketch editing mode. So current the grid in layout and in sketch are controled by same setting. I understand it's not so convenient.
So we have new improvement in coming update which enable Fusion to remember these 2 grid (on or off settings) in sketch and in layout seperately (Layout Grid, Sketch Grid).  In this way, as long as you trun sketch grid on (sketch editing mode) once, then it remembers it and you don't have to manually re-update it next time. Hope it helps. The coming update should be ready soon. Thanks for sharing!
Lori Zhang (Fusion Development)
O.Tan
Thanks!
Omar Tan
Malaysia
