Layer misalignment when importing PCB from Eagle
timh26
timh26
When transferring the board from Eagle to F360, the stop and silk layers are misaligned.
kgrunawalt
This isn't a known issue I think, so it would be great if you could share your BRD file with us if possible. Thanks for reporting it.
Feel free to email it to me at katrin.grunawalt@autodesk.com if you can.
kgrunawalt
We found the source of this problem and should have a fix in next release. One workaround is to use the default bottom-left text alignment and to position the text to be in right spot.
No need to send the BRD! Thanks and sorry for the trouble.
timh26
Thank you. When is that release expected? Is it a Fusion issue or an Eagle issue?
kgrunawalt
It is an error in the translation of the EAGLE BRD into a Fusion decal, so it is a Fusion services issue. The fix should be released in early September.
kerry.gerontianos
I'm still seeing this issue even with Eagle 8.6.2
Here's the board I'm working on.  The decal layers (top/bottom) are offset.
