Extrude Starting From Object Issue
jimskeet2002
jimskeet2002
Hi guys.
What I noticed is that extrude cut, using start from object, fails on profiles that are not cutting on a single face on the object. Like when trying to do an extrude cut on a model from t-spline that has a lot of curves and divided faces.
I will upload an example image when I'll have the time later.
Any way to bypass this or maybe it can be addressed so it allows you to choose more faces?
jeff_strater
Hi @jimskeet2002,
You are right, thank you for bringing this up.  We clearly missed the ability to extrude from more than one face, or to have a "chain faces"/"extend faces" setting for the "from" side, like we have for the "to" side.  I will log this defect, and give it a high priority.
Jeff
[edit] filed as FUS-34468
Jeff Strater
Engineering Director
jimskeet2002
That's great! Keep up the good work!
laughingcreek
@jeff_strater-Has there been any progress on this issue?  It's a weird issue. (see screen cast)
jeff_strater
No, unfortunately, this one has not yet risen to the top of the priority list.
Jeff
Jeff Strater
ibarter3d
Any idea when this is going to be fixed? Have had this issue several times.
