Laser cut tubes for a chassis
How do I start a fusion chassis build so I can later on have all the tubes laser cut ?? Just starting out on fusion but am I long time SW user..
Cheers Clive
davebYYPCU
Each part should be a component, (Rule 1)
Talk to the Laser Cutter and find out what formats they will need and work to that goal.
Making the chassis, with modelling features from sketches to fit your design.
Few quick tips.
dwoodville
Did you ever have any luck building a chassis in fusion? I'm trying to do the same thing and am having trouble determining what method will work. There will be bends in it so I'm thinking the sweep option would be valuable but I'm not sure if that can be exported for laser cutting/cnc bending.
