Large Assembly won't open
O.Tan
Advisor Advisor
O.Tan
Okay, this is my 3rd time trying to open it so I'm not sure what's going on.
I have this assembly which has its sub-assemblies reference linked. Total components is around 1000+ parts. I've waited and waited and somehow it's not opening the assembly. And no, I can't share the model but I don't understand why it can take so long to open an assembly which "technically" should be cached on the system. I understand if it's slow to open for models that hasn't been opened for 15 days, but this is an active-working file. Why does it take so long (final time, 10 mins to open the assembly)?
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
daniel_lyall
I am getting this with a assembly that has 20 parts sinces last update
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
innovatenate
Autodesk Support
Autodesk Support
Is this issue still ongoing? Are you able to open a previous version of the design?
How to open a previously saved version of a Fusion 360 design
It sounds like it may be downloading the design before opening. If you first go to the work offline mode, do you see the design in your data panel? If so, then it is locally cached.
Work in the Offline Mode
Try opening it while in offline mode. Does this cause any change in opening times?
Nathan Chandler
Principal Specialist
daniel_lyall
yes its still happing fusion has gone funny since last up date before update it was fine it would only play up like @O.Tan said but now its got a few problems
Daniel Lyall
The Big Boss
Mach3 User
O.Tan
It managed to open, it just took much longer then expected and if I compared to other CAD software (SolidEdge) this opens way too slow.
And yes, I did see the design in data panel when I went to offline mode.
I timed the time it took to open and it's as follow:
Offline - 3 minutes
Online - 3 minutes and 30 seconds.
So it seems because of the size of the assembly (1000+ components), it took a long time to open it. I hope this can be improved in the future.
Omar Tan
Malaysia
