Fule formats supported by Shapways.
glayley0
glayley0
Would it be possable to support one of the formats below so we can use Shapeways.
Every export option Iv tryed is not supported.
TrippyLighting
I've not tried shape ways but it would be very surprising if they did not support STL format. That the oldes and most widespread file format for 3D printing. You can easily export from Fueion 360 to STL.
glayley0
STL is supported by ShapeWays but isnt shown in the export dropdown.
Found it in save as STL when asn Object is highlighted.
TrippyLighting
Aha. I see!
You are looking for export in the wrong spot. YOU need to select a comonent from the broiwser, right-click on it and select export to STL.
The export menu you are looking in would export the whole model.
promm
glayley0,
You can save your file as an STL.  Below is link to a screencast that shows you how.
http://autode.sk/1WJMGwW
Let me know if you have any questions.  mike.prom@autodesk.com
Cheers,
Mike Prom
glayley0
promm thank you very much for showing me how do do it with the screen cast!
Thanks allot for all the other help. Works great although all my STL's are upsidedown but I just save them uypsidedown and they end up the right way up.
I will get this program nailed down!
