Justify Text
Justify Text
VGBenjamin
Justify Text
VGBenjamin
I would like to justify some text to do this (see attached file) but to do this I need to justify the text to make it beautifull the left and right should be justified.
So I have tried to insert text in fusion 360 but it doesn't look possible to justify the text. I have tried the same on sketchup to reimport it later but it wasn't avalable either. I have tried to create a svg with Inkscape without success either...
How could I do that please?
jeff_strater
what do you mean by "justify"?  Fusion supports left, center, and right horizontal, and top, center, and bottom justification of a text string:
Screen Shot 2021-12-14 at 1.31.59 PM.pngScreen Shot 2021-12-14 at 1.32.06 PM.pngScreen Shot 2021-12-14 at 1.32.14 PM.pngScreen Shot 2021-12-14 at 1.32.21 PM.pngScreen Shot 2021-12-14 at 1.32.28 PM.png
Jeff Strater
Engineering Director
VGBenjamin
No the justify is a bit different it is like on the right example here.
It is adding space between the caracters to ensure that the left and right characters are perfectly aligned
g-andresen
Did you convert the text to paths in Inkscape after formatting.
If not, you will not get a vector graphic in the export.
günther
VGBenjamin
Well I didn't succeeded to do it in inkscape either...
g-andresen
try again
Screencast
günther
