Just started working with Fusion - Help with Sculpting
FacebookGroupMember
FacebookGroupMember
Hi, just started working with Fusion. I found the sculpting tools in Forms to be very intuitive. I finished a model and transferred it to the regular environment and made some additional changes. After that I realized I needed to make further adjustments in the sculpt environment. Is there a way to take the model back into sculpting?
JHRendon
The only way is in yout TL, Edit it.
FacebookGroupMember
Autodesk Community thanks very much. I assume clicking edit will not undo all the work that I’ve done since that point as it would if I moved the slider all the way back?
JHRendon
Nope but if you modify the sculpt, take into account that some feautures you made later can be compromised with some lost references, fillets can change, etc.
