Just a simple loft
Just a simple loft
abdelatifs
Just a simple loft
abdelatifs
Hi guys,
Trying to make a loft happen between 2 profiles and for some reason the answer from fusion is:
"The loft would flow in an invalid direction. Try Adjusting the continuity settings. If two adjacent profiles are on the same plane, try moving one of these."
The profiles are where I want them to be, so not sure why I cannot do what seems to be according to my screenshot a really simple loft.
JDMather
Can you File>Export and then attach the *.f3d file here?
Your screenshot might have been just a bit more informative if you had expanded the Construction node and the Sketches node.
abdelatifs
Hey JDMather,
Thanks for your help, here it is
