June Fusion 360 update fails
Hi All
I am having a problem with the latest update of fusion 360.
Open as normal, update will be installed and will ask for restart. OK
Download gets to around about 20% then fails.
Notification to check log file, dont know where this is, and probably not much use to this thicky 🙂
Can anyone help please
jeff.pek
Hi -
Sorry you're having problems.
The deployment log location will vary depending on platform.
On Windows, this should be in: %LOCALAPPDATA%\Autodesk\autodesk.webdeploy.streamer.log.
(Just paste this into the Windows Explorer address bar)
Can you check if you have this file, and post if available?
  Jeff
Thanks for the help but still can't find the log?
innovatenate
Autodesk Support
Autodesk Support
Another suggestion may be to do a clean uninstall and re-install.
Steps for a Clean Uninstall:
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/How-...
Next, go to http://fusion360.autodesk.com/ and select the Download a Free Trial link to begin the install process.
I hope this helps.
Nathan Chandler
Principal Specialist
Sorry for the delayed reply, a clean re-install worked.
