Solved by jeff_strater. Go to Solution.
Hi @lama_aqel88,
Good question. In general, no, Fusion cannot really do this kind of complex joint (if I understand your question - you want one component to follow a path in another component, I believe). You can add two joints between the same objects. Fusion will warn you, because that can often result in conflicting joints.
Regarding your second question: There is no way to day to make a single video out of multiple motion studies. If it were me, I would make separate videos, and just edit them together using video editing tools.
Sorry not to have a better answer for you.
Jeff
I'm trying to do the same... only with a pin and a metal plate, where the metal plate has a track cut out for the pin to follow, with multiple directions. I have no idea how to do it 😞
