Joints not working as expected
chris_heath01
chris_heath01
Hi - I am trying to create a concealed SOSS hinge (hafele 341.07.718.1) - I have the basic hinge and it sort of works, but it's very flakey.  The joint that I use to drive the whole assembly is revolute 29 to its maximum of 120 degrees - when I set a motion limit to 120 degrees the joint stops working.  I'm not sure if it's the design or my Mac running out of processing power.
Thanks for looking at this post,
Kind regards
Chris.
jhackney1972
You do not need Contact Sets in this model.  You left of two Pin-Slot Joints where the pins run along the hinge body slot.  Select the Drive Me Joint, in the Browser, and right click.  Select Animate Joint Relationships to activate hinge.  Model is attached.
If my solution solves your Forum question, please select the Accept Solution icon on my post. If you have further questions, let me know.
John Hackney, Retired
chris_heath01
Many thanks for your help - have not used pin slots before.
Kind regards
Chris
