Every update fails
Every update fails
ellis_woollatt
Every update fails
ellis_woollatt
Attached is log file
RajkumarIlanchelian
@ellis_woollatt Please uninstall Fusion first and then follow the below.
1. Make sure that Fusion installer is not running in task manager
2. Go to %localappdata%\Autodesk\ then DELETE the following folders – Webdeploy, Web Services, Identity services, Autodesk Fusion 360 ((IF you do not have any other Autodesk products installed, delete the Full Autodesk folder)
3. Delete the shortcut that is used to launch Fusion
4. Restart your machine
5. Do not use the same Fusion installer. Can you please download the installer again
6. Now install again
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
