Jointing - Revolute Between Two Faces Failing
docara
docara
Hello
I'm trying to joint a component using the Revolute and theBetween Two Faces option across three components. A mounting plate, an inserted bolt and a bracket
Image 1 is the plate and bolt, Image 2 is the machined bracket showing recessed shoulders.
The command works fine for the source object (image 2) - I can select the two inner faces and click on the mid point along the hollow 'shaft'. Now I need to position the mid point selected above between two other faces of the bolt and plate (image1) of a destination position but the command won't complete.
Am I doing anything wrong or is it another bug
Matt
TrippyLighting
That “between faces” only works if each of the two faces belongs to the same body.
