Message 1 of 9
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi
I'm busy with a robot (Bender from Futurama) that can rotate arms and open its belly door with a servo. I have now constructed the door and hinge, but when I make a revolute joint, the door clearly does not rotate around the axle point. As I simply extruded the hinge from the door to the frame, I was expecting the two surfaces to be parallel. I have no clue or "best method" to construct a door or hinge of this type, so I gave it my best shot, but after two weeks, I have not produced anything workable.
Any help would be much appreciated. Here is a video link to my problem: https://autode.sk/311c0XY
