Joint troubles
Joint troubles
smallfavor
Joint troubles
smallfavor
This is an assembly of components with orbital joints.  I was hoping for something more IK but even so, it seems to be less than easy to pose.  I have continuing issues with the axis of the joints - that is they continually seem to be oriented 90 degrees off what's desired.  Trying to make them right with the degree setting in the command fails.  And I also get some less than clear error texts.
Beyondforce
Hi @smallfavor,
Have you tried to use the Revolute joint and limit the movement?
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
HughesTooling
Only the joint at the base of the finger needs to be a ball joint the others should be Revolute as @Beyondforce suggests. If they are 90° out try using "Joint Origin" to create a joint with the correct orientation.
Mark
Edit
This help link might help
http://help.autodesk.com/view/fusion360/ENU/?guid=GUID-819D04C8-A3C1-4B4F-A048-DD0A7002D05A
Mark Hughes
Owner, Hughes Tooling
smallfavor
Thanks!
smallfavor
Thanks!
