Joint to ground?
Joint to ground?
joergen_nilsson
Message 1 of 10
Joint to ground?
joergen_nilsson
Can I create a joint directly between a part and ground, without having to model a second dummy-part just to make it grounded? For instance if I'd like to rotate a wheel with a revolute joint without modelling the wheel hub.
Replies (9)
Message 2 of 10
jhackney1972
Sure, make the top level Origin visible and create a Joint between your component and the Origin Point.
John Hackney, Retired
Message 3 of 10
jeff_strater
You can create a revolute joint to the root component origin, which would allow you to create the relationship I think you want.
(view in My Videos)
Jeff Strater
Engineering Director
Message 4 of 10
jhackney1972
If my Forum post solved your question, please select the "Accept Solution" icon to do three things. First it allows others to find a solution to a similar question, two, it closes the Forum post and last, it acknowledges that you accept the solution given. If you need further help, please ask. If you like to read why "Accept Solutions are important, take a look at this webpage.
Message 5 of 10
Drewpan
Why do you need a Joint to the ground? Shouldn't you simply ground the object then manipulate it?
Cheers
Andrew
Message 6 of 10
laughingcreek
@Drewpan wrote:
Why do you need a Joint to the ground? Shouldn't you simply ground the object then manipulate it?...
OP stated he wants a revolute joint so he can spin the object.  not sure how grounding and then "manipulating" it would be of use.
@joergen_nilsson - if you have built the body of the component "in place", meaning it is already where you intend it to be, you can use an "as built" joint between it and the top level.
(view in My Videos)
Message 7 of 10
Drewpan
Oops! My mistake.
Message 8 of 10
joergen_nilsson
Perfect, that was a neat solution 🙂
Message 9 of 10
wkearneyFVALX
Community Visitor
Community Visitor
With a recent update "ground" seems to be missing...
What am I missing?
Message 10 of 10
jeff_strater
the old "Ground" is now "Pin", and there is a new "Ground to Parent" (anchor icon), which just implements the solution in message 2 of this thread (creates a rigid joint to the parent's origin).  This allows the relationship to survive the Insert operation (the old Ground was stripped on insert).  Makes it easier to create rigid sub-assembly.
Jeff Strater
