Joint Moves Wrong Part
jresciniti
Observer Observer
jresciniti
Observer
Observer
Hello all,
I'm very new to Fusion 360.  Only my third day using it.  I have an STEP file that I downloaded and opened.  I copied and pasted a body in from another file, and when I try to make a joint between the bodies it will only allow me to move the original body to the part that was copied and pasted.  I can't move the part that was copied and pasted to the body.  The problem is that it then moves the entire model off the original center point so I can no longer mirror future modifications about the original axis.
When I use the joint command, It will only allow me to select a face on the original body first.  I don't understand why.  Any help is welcomed.
jeff_strater
I think we need more info.  A video/screencast of what you are trying to do, and the model itself.  Most likely, this is easily explainable, but we'd need to see more to be sure.  Thanks.
Jeff Strater
Engineering Director
