Joint displacement or refresh error?
development
development
I have a Joint with two Joint Origins. All is OK, but when I'll reopen the file project or roll back the History Marker, the Joint is displaced. See the Screencast...
Do you know what's wrong?
James.Youmatz
Autodesk Support
Autodesk Support
Hi @development,
Hmm, that does seem a little strange! Just to check - what happens if after you roll the timeline back (and the joints are displaced) and you go to the Modify Menu and select Compute All. Does the location of the component change or do any errors/warnings pop up?
Also, for those inserted components, if you open those original files up, do you have any pending position captures? For instance, did you move a component and then not select the orange Capture Position button to capture the new location for the moved component? I'd be curious to see if this is what might be causing the issue as well.
Feel free to invite me to the project as well so I can take a deeper look! My email is james.youmatz@autodesk.com
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
development
Thanks for reply.
It is little strange for me but in this case Compute All command solved the problem! There was no errors and warnings before and after Compute.
I'm using parameters in linked components and it was changed many times, so maybe it was the cause.
Thank you very much for your help.
