Joint conflict in assembly with multiple occurances of component
Message 1 of 21
I am trying to build an assembly with components which repeat over and over again. I built the Components in their own designs and then inserted them into a new design which is the assembly. When joining the parts in the assembly Fusion shows an error for joints which should have no conflicts. While trying to figure out why this happens I built two designs which illustrate this and have joint errors, which I don't know how to deal with.
In one design the geometry fits together but the last joint creates an error. In the other design having multiple occurrences of the same component creates a conflict. Fusion seems to apply each individual joint to all repeating occurrences of the component. I have added two public links to these projects, I hope they work and allow you to see everything relevant.  I am not so familiar with how the sharing function in fusion works. If this doesn't work I will create a screen cast and add it.
https://a360.co/2MbFSrZ
https://a360.co/2kY96y0
thank you in advance for any help or advice, I am stuck and a little frustrated at the moment.
-Markus
Replies (20)
Message 21 of 21
plutoh
Community Visitor
Community Visitor
I have the same problem with multiple ocurrences of the same component in an assembly. I dont have any joints neither any other features just only the components placed. When I try to select the components Fusion 360 crashed.
Please anyone can help me?
