Hi all,
I'm having a hard time with reconciling joint compute warnings in my design. After digging around on the forums, I locked my sketches which weren't previously fully defined (all black lines, not sure why they weren't presenting as fully defined), tried redefining various joints in the design, and suppressing individual joints to see if I could identify the offending joint, no joy. Something about the interaction of the "retention link to base pin-slot" joint has caused all of the joints to fail, even when I apply constraints for the sliding movement range of that joint. This feels to me like I'm just missing something about how joints need to be implemented, maybe I'm using the wrong kind of joint somewhere? I'd welcome anyone's recommendations as to where to go digging next, and if it looks like I've missed some major block of Fusion360 training, I'd love recommendations on which courses I should complete. I've attached my design export for reference, and have done my best to abide by rules 1 and 2, pardon the probably bad terminology as MechE isn't my primary discipline. The intended function of the design, in case it's not clear, is the movement of the lever component moves the catch and catch-hook in and out of the base, and once the catch-hook component has been pushed beyond the base, the retention link pulls the catch-hook vertically.
