continuous blocks of the program in the selections
I keep having program blocks that make copying or dragging groups of objects unmanageable, in my project there are hundreds of bodies and components ... when I select a part of them the program freezes and a core remains occupied on you are for even 5 minutes. impossible to use except for hobby drawings
SaeedHamza
Try using the selection filter.
Because if you select using for example a window selection, it will select bodies, faces, edges and vertices, which is too much for Fusion to handle if the project contains too much bodies and components.
Saeed Hamza
