Joint between two faces on two bodies
Hi Folks,
I'm Solidworks certified, but I can't afford it for personal use so I've decided on Fusion 360 (thanks Autodesk! C'mon Dassault, step up to the plate!). I started with Inventor, and noticed how much easier it was to use when I started using Solidworks at work. The one area Fusion 360 falls flat, however, is joints. It seems that I can't apply several joints to the same parts, the relationship I want seems to have to be defined in one operation as opposed to several. I find it very counterintuitive and was hoping someone could help me out.
Here's the situation: I'm creating a small engine to use as a teaching tool for my friends and family. It's very rudimentary at this point, but I still can't seem to create the joint I want. I'm trying to insert the crankshaft/piston assembly in the crankcase, which consists of the crankcase and a crankcase cover. I can't seem to figure out how to do a 'between two faces' joint that places the crankshaft between the faces of the crankcase and the cover.
I've attached an image, the goal is to have the crankshaft axially equidistant from the internal faces, but Fusion doesn't seem to like the fact that the faces are on two separate bodies (the crankcase and cover). Any help would be appreciated.
Marco.Takx
Hi @Anonymous,
See this link to learn how to place a joint between 2 faces.
Quick-tip-adding-joints-between-two-faces
If my post answers your question Please use Accept as Solution & Kudos This helps everyone find answers more quickly!
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
davebYYPCU
Why?  Joints are so easy.  When you find a common point on both parts, in your case you have colinear axis.  Pick a point along them.
One Revolve Joint on the end face of the shaft, aligned to the centre of the hole in one end of your Case, Offset Z along the Axis half of the gap.  Done.
Might help....
TrippyLighting
Looking at your signature I would recommend that you upgrade to Windows 10 soon. Microsoft and the Fusion 360 team have officially ceased support for Windows 7.
