Joining Two Form Bodies
kellnerd
kellnerd
I am working designing a lamp within the Form workspace and below shows the issue I keep running into. Every time I use the merge edge function and even use the Repair utility, I keep getting a T spline error. Any help would be appreciated
Replies (9)
TheCADWhisperer
@kellnerd
kellnerd
Yep! Here's the f3d file attached
TrippyLighting
Take a loo at this topology and see if that is what you are looking for.
When joining T-Splines you need to consider the number of edges/faces when modeling either of the halves.
kellnerd
That's exactly it! I was wondering how you joined the faces from the stem to the base?
TrippyLighting
I can create a screencast later today.
kellnerd
Yes that would be amazing thank you! Very much appreciated
TrippyLighting
Here is the screen recording. It will YouTube still take over an hour (from the time of this post) to  convert the upload into 4K video, so be patient.
kellnerd
Amazing video thank you so much! Very insightful and helpful
TrippyLighting
Thanks! Can you accept my post as the solution?
