Add Both Flat Pattern & Folded Model to Drawing
cadmodeller
cadmodeller
Since a recent update I can't seem to add both a flat pattern and the folded model to the drawing I'm drafting.
I have the option to have the model folded or unfolded in the timeline but I can't seem to have both versions present in the drawing. The model view is the only available representation even though the flat pattern has been created at some point in the timeline.
Has anyone else experienced this and can someone point me in the right direction?
cadmodeller
Solved the issue myself, it turns out I needed to click 'Create Flat Pattern' under the create menu instead of 'Unfold Model' in the modify menu. 😀
-KyleWilliams-
For a sheet metal drawing I would expect to see the options in the drawing view dilogue seen below. If you are able to share a file I might be able to see what your issue is. You can share it here, or send it to me directly at kyle.williams@autodesk.com
Kyle Williams
Senior Customer Advocacy Manager - Design and Documentation
Ontario, Canada
Become an Autodesk Fusion Insider
