Joining line segments in sketches
Theoforus
Message 1 of 9
Theoforus
How can I join the lines in this sketch to make it easier to work with. When there are so many small line segments it is esy to miss a small part. Skjermbilde 2021-12-28 kl. 12.50.47.png
See attached fusion file for mor info.
Replies (8)
Message 2 of 9
Ex_Machina_Engineering
Lines and arcs are separate sketch entities. So you cannot join two of them to make one new one. But you can delete all the small line segments in a straight line, leaving only the start and end of it, and then draw a new line in their place.
Is that what you were after?
Message 3 of 9
Theoforus
no, not really. But a good suggestion. Would be nice to have the
possibility to convert all the small lines to a spline.
Could it be done by the offset tool? Just use the tool and have zero
offset?
Message 4 of 9
No, the offset tool will create one entity per entity...
Message 5 of 9
TheCADWhisperer
I would start over from scratch and create each and every element as fully defined high-quality geometry.
I would not have any dimensions that I cannot measure with calipers.
I would have the small ellipse geometry on a separate sketch.
Message 6 of 9
etfrench
  1. Extrude
  2. Convert to Mesh
  3. Create Mesh Section Sketch
  4. Edit sketch
  5. Fit Curves to Mesh Section
ETFrench
Message 7 of 9
Theoforus
Would it be the same with the revolve tool?
I am not familiar with using mesh. Could you show me an example?
Message 8 of 9
Theoforus
Do you suggest to first make a basic full defined sketch and than make another one with the small details?
Message 9 of 9
etfrench
This explains the process (but don't move the sketch).
p.s. In your case, this will be as much if not more work than recreating it as @TheCADWhisperer  suggests 😁
ETFrench
