Joining faces
Joining faces
vegard.midtboen3DK2Q
Joining faces
I have just started using Fusion 360. I have recently used SolidWorks, so there are some concepts that are a bit difficult to adapt to. I'm trying to mate/join a fastener between a floor and a wall. What is the best way to join this?
Before jointBefore jointHow it should be joinedHow it should be joined
Rafal.Chlod
Autodesk Support
Autodesk Support
Hi @vegard.midtboen3DK2Q, thanks for posting.
I'm not sure if this will be the best and most efficient method, but I've managed to create a similar joint using the Two Edge Intersection option when creating a joint. You may need to move the element and rotate it by the appropriate angle. This can also be done while creating the joint.
If my answer helped you, please click Accept Solution. Thanks!
Rafał Chłód
Global Product Support
My Screencasts | Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
Hi @Rafal.Chlod , thanks you your support.
By using your approach, I managed to create almost what I wanted (see photo). However, this approach does not join the fastener to either the floor or the wall, meaning that if I changed the plate thickness, I would have to changed the offset distance as well. It should have been possible to snap to objects instead of offsetting it a number (maybe an input to further improvements??).
seth.madore
I'm also not a modeling guru, but I used a similar approach, and I'm able to edit most anything without losing positions. I did make 3 joints and I've got a couple dimensions that will update when another component has changed size. Take a look at this file and see if it helps you out
Seth Madore
Hi @seth.madore
Thanks for your help. I think this is as close as I can get to a solution.
