Issues with preselection highlighting of sketcher constraints, and with the highlight color.
johan.rutgeerts
johan.rutgeerts
I often have difficulties in a sketch to find out which geometry is referenced by a constraint.
I noticed some odd behaviour on preselection highlighting, see this screencast.
Am I missing something obvious, or is this inconsistent behaviour?
Re. the colour of the highlighting:
As constrained geometry is black, it is hard to distinguish the dark blue preselection highlighting.
I looked for a way to change the colour, and found reference on the forum to some XML files.
I found this post on where to find those files, but I don't know which entity to change in that file to change the preselection highlighting.
Thanks for any info,
Johan
abhinav_singh
Please see if your concern is similar to this thread.
https://forums.autodesk.com/t5/fusion-360-support/i-continue-to-struggle-with-constraint-highlights-...
Abhinav Singh
Product Owner
johan.rutgeerts
@abhinav_singh  Thanks for pointing out that thread, I had searched the forum but apparently with wrong keywords as I didn't see it.
It's similar, however my screencast shows extra issues, so imo it's worth to have a look and also include this in your improvement ticket.
Are you're responsible for the sketcher? If so I kindly invite you to also have a look at this thread on dragging of partially constrained geometry and this post about underconstrained geometry being black instead of blue.
Thank you,
Johan
abhinav_singh
While I am not the point contact for this module of Fusion 360, I have added a link to this thread on our internal improvement ticket (mentioned in the other thread) and have requested the concerned team to look into your suggestions as well.
Abhinav Singh
Product Owner
