Issues creating a slanted roof in fusion for an irregular shape
PRUT
Message 1 of 11
PRUT
Hi am new to fusion and i am making a model for an irregular shaped shed and cant seem to find a way on how to make the slanted irregular roof face i have tried using the sweep feature but with little luck.Screenshot 2024-04-26 232504.jpgScreenshot 2024-04-26 232604.jpg
Replies (10)
Message 2 of 11
Warmingup1953
Why not use just one Sketch? The Plan view of your shed. Extrude that Quadrilateral up to the height of the tip of your roof's pitch. Then considering your desired direction of fall modify that solid body.
Message 3 of 11
laughingcreek
one way to approach this.  adjust the parameter "rise" for the slope you want.  (rise=2 means a 2:1 roof pitch).
Message 4 of 11
Warmingup1953
By that I mean in simple terms this approach. I created a sketch and offset a line that is parallel to the widest axis of the roof. Have you embarked on any staged learning for Fusion?roof.jpg
Message 5 of 11
davebYYPCU
Based on those pics,
Fully define your sketches, (only need 2 sketches)
one way,
Solid > Create > Loft.  Select front wall to rear wall.
Solid > Create > Shell, set wall / roof thickness.
So many ways to get there, but not enough info on what you need from Fusion.
Whats in the top bodies folder?
Might help….
Message 6 of 11
etfrench
Here's another method using thin extrude and replace face commands:
(view in My Videos)
ETFrench
Message 7 of 11
PRUT
Hi thanks for all the solutions here is the file . To confirm i was struggling to make a plane using the 2 non-collinear lines.
Message 8 of 11
laughingcreek
as you have it drawn your roof won't be planner, it will be potato chip shaped.  Is that really what you want?
the model I attached previously has the lowest edge running horizontal and sloping up from that.  That's generally how it would be done in the construction, trade for good reason.
Message 9 of 11
PRUT
Hi yes  i was asked to make a model of it and the shape was potato shaped is there any way to make it potato shaped i have tried  looking it up haven't had any luck
Message 10 of 11
g-andresen
give this a try
(view in My Videos)
günther
Message 11 of 11
PRUT
Oh my thank you so so much this really helped
