Issue with obj file scale
Hi everyone,
I write to the next situation in relation with to imported file, specifically with a laser file. The file extension is .obj, initially the scale and measurements are correct, but when inserting this file in Fusion 360 (upload) appears disproportionate, considerably increasing its size.
I checked the program settings, preferences, but it still keeps the same problem.
Comments are welcome. Regards!
HughesTooling
Use insert mesh from the insert menu, don't import using the data panel. The insert option lets you set the units the file was created in.
Mark
Mark Hughes
Owner, Hughes Tooling
