Dimensioning Drawings
When including dimensions to a design drawing, diameter and radius measurements are shown as straight lines at an angle. Is there a way to places the numbers horizontally instead?
TheCADWhisperer
Can you use ASME standard rather than ISO?
julia.paganucci
Autodesk Support
Autodesk Support
Hi @Anonymous,
Try using a linear dimension- you can choose the points at which you're measuring from. You can always include the diameter/radius symbol after by double clicking on the dimension and inserting a symbol.
Let me know if you have any other questions!
Julia Paganucci
Technical Support Specialist
| Autodesk Knowledge Network | My Screencasts | Fusion 360 Webinars | Tips and Best Practices
cmiller66
Hi muangthai_par,
As TheCADWhisperer mentioned, the dimension style used in the drawing (including the text alignment for diameter dimensions) is set per the standard (ASME/ISO) of the drawing.  There are other settings like 1st/3rd angle projection and inch/mm unit sheet sizes which also get defined per standard.  Currently we can't overwrite individual dimension style settings like diameter dimension text alignment.
Chris
