Issue with design, help wanted
isaacfrazerb
Message 1 of 18
isaacfrazerb
Hi there, I’m currently designing a ball bearing assembly but have run into an issue with the cage, I’m trying to make a cutout for the steel balls to snap into but fusion won’t let me cut how I need to and I can’t change cage dimensions, tried every workaround I could think of but to no avail so thought I’d ask smarter people lol.
Replies (17)
Message 2 of 18
pendean
Community Legend
Community Legend
@isaacfrazerb which Autodesk software are you using please? This forum is not for software assistance.
Message 3 of 18
isaacfrazerb
Sorry I’m new to using the forums, I’m using fusion360
Message 4 of 18
pendean
Community Legend
Community Legend
I'll notify the admin to move your post to that software's forum. Best wishes.
Message 5 of 18
TheCADWhisperer
@isaacfrazerb
Once you have Attached your attempt here, we can continue the discussion.
Message 6 of 18
lauri_barnhart
@isaacfrazerb - Welcome! Thanks for your question.
Are you still in need of assistance with this? Did you also see the reply above from @TheCADWhisperer?
If your issue is now resolved, please share the details with the community.
If you still require support, please post an update so we can assist you further.
Best,
Lauri | Community Manager
Message 7 of 18
isaacfrazerb
Sorry yes still need help my computer stopped working for a few days I’ve fixed it now but not resolved issue with design
Message 8 of 18
isaacfrazerb
Thank you sorry my computer stopped working for a few days I’ll work on getting the design to here now
Message 9 of 18
isaacfrazerb
Last message sent contains exported file hopefully you can open it without any issues
Message 10 of 18
TheCADWhisperer
@isaacfrazerb
What is your source for the dimensions you have used (do you have a link)?
You have more dimensions than needed.
Yet you are missing critical dimensions.
Illogical dimensions.
Message 11 of 18
isaacfrazerb
Going off of one my uncle designed that he’s 3d printed, the outer circle is just additional material material to be taken away on top of the size the balls will be so that they snap in relatively easily, I think my uncle originally made his from being inspired by a YouTube video that did it a similar way I could try to find if that would help?
Message 12 of 18
programming2C78B
I dont see what the issue is. Just expand your Objects To Cut dropdown and ensure all 3 are selected, if that's your goal.
the sketch needs to be fixed/constrained ASAP
Please click "Accept Solution" if what I wrote solved your issue!
Message 13 of 18
isaacfrazerb
I’m just trying to make the cut in body5 I believe (the cage) and I’ve tried revolving the circle I’m cutting as a sphere and also tried using create sphere as a cut neither works, I’ve used as many constraints as I believed I need could you elaborate on what constraints I need in the sketch? Is that the issue?
Message 14 of 18
isaacfrazerb
Could you try making the cut I’m trying to make it’s the 4.5mm center point circle revolved as a cut through 360° cut into the cage which I believe as I say is body 5 but I can’t seem to get it to work
Message 15 of 18
programming2C78B
A sketch should not have a single blue line in it before you do any Features.
I didnt watch this but Im sure its right based off the title
https://www.youtube.com/watch?v=iyc7urh8jhQ
a) Why did you revolve this, mirror it, and mess with Moves when you could've just drawn this all correctly in a single sketch? Arguably one of the worst ways possible of going about this. You never want to Move things (use joints) and you never want bodies to overlap (unless using a Join command after)
b) the file you attached already has a sphere cut out
Message 16 of 18
TheCADWhisperer
@isaacfrazerb
Step 1 Start a new file and sketch a Rectangle at the Origin as shown below.
Crossing Window select the three lines to the right and hit x on the keyboard to toggle to Construction.
Select the vertical line from the origin and right click toggle to Centerline.
Add the dimensions shown below.
Observe the red padlock symbol on the sketch after adding the dimensions.
@isaacfrazerb
Now add a Horizontal Construction Line from the Midpoint of the Vertical Centerline over to the right past the Rectangle.
Add the dimension shown.
Observe the red padlock on the sketch after adding the dimension. (Click on the image below to enlarge the view.)
Now add a Circle at the end of the horizontal midpoint construction line.
Observe the red padlock symbol on the sketch glyph in the browser...
Now add a short vertical line in approximate location shown below.
Add the diametral dimension.
Add a Coincident Constraint between the top horizontal construction line of the rectangle and the top ENDPOINT of the short vertical line that we just created.
Observe missing red padlock symbol on sketch
Now sketch a short Horizontal line, and angle line and then a Vertical line (overtop of the construction line) as shown below...
Add the two dimensions shown below to constrain the angled line.
Observe the color change of the angled line after adding the dimensions (the actual color depends on your background color - might be different than my image).
Message 17 of 18
TheCADWhisperer
@isaacfrazerb
Now add an angled line from the short vertical line down to the midpoint construction line.
Add the 45° dimension as shown below.
Now add a Tangent constraint between the 45° line and the Ø4.1 circle.
Observe the return of the red padlock symbol on the sketch (the sketch is once again fully defined).
Hopefully you anticipated the next step.
Add a Tangent Constraint between the vertical line and the circle.
Observe the red padlock symbol on the sketch.
Next go to the Surface tab and select Patch.
Click inside the boundary to create the patch (we will see why this technique in next step).
Attach your progress file here for next step.
Message 18 of 18
TheCADWhisperer
@isaacfrazerb
Where did you go?
