Since the last update when in the design environment I start a sketch, choose the line tool an start to add lines, after some times one line and some times after a couple of lines the grid disappears and the lines being drawn disappear,
I have included a screen video to show what I mean
Thank You
Michael
Solved by Drewpan. Go to Solution.
This type of issue most commonly seems to be graphics driver related and is usually fixed by changing to the
alternate and back to the original, or installing the latest driver.
Cheers
Andrew
Thank you for your reply
I tried what you suggested and it seems to have fixed the problem
Thanks again
Michael
