Is there an easy way to make an STL into a usable body in Fusion 360?
It says this file has too many facets. Is there a simple way to reduce the number of facets in order to use this file to make a case? This is the file I'm trying to use: http://www.thingiverse.com/thing:412639 Any help would be greatly appreciated.
Mike.Grau
Hi @Anonymous,
Thank you for your post in the Forum.
I have downloaded the file in the link and start working on it.
I will check the file format and see what would be the best way to work in Fusion 360 on the design.
We will keep you updated.
PhilProcarioJr
@Anonymous
That file has a STEP file in it, all you have to do is New Design From File and open the STEP file.
Phil Procario Jr.
Owner, Laser & CNC Creations
kevmaggard
Mike.Grau
Hi @Anonymous,
Thank you for asking about the PCB you would like to import into Fusion 360.
Yes, the step file converted into closed bodies with public link.
http://a360.co/2d7vEGf
I hope this helps. Please, keep us updated if this file working for you.
