Is there a way to revert/downgrade to the previous version?
I updated yesterday but now things seem a little jacked and I can't do any work now.
The main issue I'm having is the ability to move an imported SVG sketch object. I used to be able to move the imported sketch or sketch object by selecting it. In this version I can't select the object. There do not seem to be any constraints to clear or anything obvious preventing me from selecting it. I can select it if I extrude the sketch into a 3D geometry, but no dice as just a sketch. Super frustrating.
Anyhow, I've spent an hour trying to move imported geometry and it pretty much sucks my will to live. How do I downgrade?
HughesTooling
If I open the SVG sketch select all and click Fix\Unfix I can move an imported SGV OK, are you trying something different.
Another option is to move the sketch into a component then move the component.
Mark
Mark Hughes
Owner, Hughes Tooling
Phil.E
Hi @Anonymous,
Welcome to the Fusion 360 forum.
The short answer is no. Each update is necessary and progressive. It sounds like @HughesTooling has a solution for you, please let us know if it works.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Thanks! This totally does the trick. I'm coming from Solidworks and there are still a few hidden variables for me in Fusion 360. In this case I was expecting that the reason I couldn't select the imported sketch object was b/c there was some constraint I was missing, but after taking your advice the placed SVGs are just 'fixed'-- the curious thing is that DXFs don't have the same issue.
