Is there a way to mirror a component and keep it linked to the source component?
不适用
1,352 次查看
2 条回复
1 条消息(共 3 条)
不适用
Hey quick question
I am redesigning cabinetry.  I'm setting up each of my doors as individual components.  In the case where there are two doors (components) side by side that swing away from each other, I want to mirror those.
However, if I mirror one door, then make a change to it, it doesn't change the mirrored component.
If I use copy and paste, it does update the copies... however, there is no way that I know of to mirror the copy, only rotate/translate it.
What's the best course of action here?  Thanks!
0 个赞
已接受的解答 (1)
1,353 次查看
2 条回复
回复 (2)
2 条消息(共 3 条)
TrippyLighting
已接受的解答
Beware of the timeline 😉
In order for the changes to be reflected in the mirrored copy you'll have to travel back in the timeline and make the changes before the mirror feature in the timeline.
0 个赞
3 条消息(共 3 条)
不适用
Oh ok, thanks for the tip.
It always throws me off when certain things work one way in one mode, but a different way in a different mode.
0 个赞
