Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Is there a way to make joints stay locked or unlocked?
Noah_Katz
Message 1 of 31
Noah_Katz
My assembly has lots of moveable joints and I often want to keep some of them either locked or free while I work on a particular area of the design.
However, I'm constantly having to re-lock or re-release them, seemingly from doing almost anything other than just looking at the design.
Modifying components (via their sketches), moving through the timeline and back (which I guess happens when editing sketches), perhaps moving other joints, and I don't know what else.
Is there a way to make the joint setting stick?
Replies (30)
Message 21 of 31
MichaelT_123
Hi Mr Noah_Katz,
The Fusion360 model does not have joint lock functionality, at least directly. Indirect, although the cumbersome way is pointed out in the previous posts.
Instead, there is the option to lock particular kinematic types (motions) of joints. It is simple and easily accessible.
Additionally (after some rumblings) F360 has been 'upgraded' to expose this function in API.
https://forums.autodesk.com/t5/fusion-360-api-and-scripts/jointmotion-lock/m-p/7556995
Regards
MichaelT
MichaelT
Message 22 of 31
Noah_Katz
My original post was based on locking a single allowed DOF, so as far as I'm concerned that's a minor semantic distinction.
Message 23 of 31
brad9126
My experience with this little lock feature button is that it only lasts until you click on another function or move another joint. For me, it does not "stay locked until you unlock it" as it says in the flyout when you hover over it. I see this as a glitch and wish they would fix it for all the reasons that Noah points out.
Message 24 of 31
jhackney1972
If you Lock a Joint, then press the Capture Position Icon, the Lock will be maintained until you Unlock it.
John Hackney, Retired
Message 25 of 31
brad9126
That works. Thanks so much for the info!
Message 26 of 31
TrippyLighting
@Phil.E I assume that is not the intended way it's supposed to work. Could you please direct this to the correct team?
Message 27 of 31
Noah_Katz
That makes sense, thanks!!
Message 28 of 31
phil_eichmiller
I need more info. In this image, the mailbox (letter box) door revolution is locked. I then edit/drag the Flag joint, and the door joint remains locked. If I can get this to fail, I can log a bug report. Please provide a video or simple design that shows the issue. Thanks for helping.
Message 29 of 31
Phil.E
The response above was made from my EDU account. For the record, I am an Autodesk employee.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 30 of 31
jhackney1972
Attached you will find a video where I try and explain what everyone is talking about with the Lock Joint.  Normal practice, it to Revert Position when created a new Feature in an Active Component so the Lock on any Joint is lost.  If on the other hand, you select Capture Position when promoted, you will retain the joint lock.  Model I used is attached.
I responded to your Educational account, I will also tag you here @Phil.E
(view in My Videos)
Message 31 of 31
Phil.E
Thanks for clarifying. I see the issue now.
(Logged report FUS-195888)
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
