Is there a way to go specifically to "joint movement" mode?
ittay.dror
ittay.dror
When I have a complex plan, most of the time when I click a body and start to drag, Fusion will create a window selection. How do I "force" it to move the body according to its joint movement instead (it can move) ?
laughingcreek
can you screen cast what's happening?  when I do it, I get window select if my selection point isn't on a component, but if I the first selection point is on a component, the component moves instead of trying to window select.  could be something up if that's not what's happening for you.
