Is there a way to determine if my sketch is fully defined/constrained?
Is there anyway to determine if a sketch is fully defined/constrained? I don't see any kind of color change like in SolidWorks?
see example:
 Thanks!
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
So we actually have a Preview feature that you can turn on that will change the color of the sketch depending on whether or not it is fully defined. To enable this:
  • Click your name in the top-right corner to display a drop down menu. Select Preferences
  • Select the Preview Tab
  • Check Sketch - Color sketch geometry based on constraint status
Hope this helps! Also, in the Inspect menu is a tool called Check Sketch which can help determine if there are open/closed profiles in your sketch. Edit: Just realized this is an add-in that I downloaded from the Autodesk App Exchange here, in case you are interested.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
schneik-adsk
There is one more way to tell. In the browser open the sketch folder. Fully constrained sketches will have a "pin" in the upper left corner of the sketch icon. This will also tell you if the sketch is fully defined/constrained. See two sketches here. Sketch 2 is fully constrained.
Kevin Schneider
This is perfect. Thanks!
Thanks for the help!
