I often import STL's into my projects and every time I do so I have to click the browser and select "Do not capture design history" This gets pretty annoying because I use the design timeline all the time and if I don't import all my STL's at the beginning of the project, it deletes my design history when I re-enable it. I know I can turn the history back on after I convert the files but I don't want to have to disable it in the first place. Anyone know how else I can convert STL's to Brep (or anything that will allow me to edit them) without disabling my design history?
Thanks in advance,
Justin
Solved by HughesTooling. Go to Solution.
Yes, create a base feature with it active select the mesh and right click and you should have the option to convert.
Mark
Mark Hughes
Owner, Hughes Tooling
Seems to work, Thanks! I've been doing this the hard way for far too long
