"Based on your comments I am wondering if you've watched the introductory tutorials in the Learn section yet."
I have watched many videos and lessons from the help section not to mention YouTube videos. I am not using most of what the Learn section talks about. I am working with sheet metal. That is a very limited application of Fusion. I found the chapters that talked about what I am doing and explored those. I have not watched everything, and I have not used the Assembly menu option at all. I am still creating correctly shaped components.
Here is how it goes over here. I define a 3-D cube or rectangle, then use negative extrusions to remove metal so to create a sheet metal form. After, I use rectangles with negative extrusion to cut the form to the shape I need.
With the plane issue, I am drawing a body to cut a component. I am creating rectangle to be used in cutting away areas of the "metal sheet" form.
This program has lots of, not ready for prime time, issues in it. One is the weirdo plane limitations. You should be able to Sketch in any plane anywhere at anytime. I am having problems with that. I do have a work-around. Fusion lets you move bodies in any plane or direction. So I just make a body, then flip it however I want. It just seems odd to me. Then I cut.
So I guess I am correct about the plane issues? Sounds like it from your answer.
What would be nice is a way to know that you have moved a component into the space of another component, violating it. Maybe just a switch option that you can select that will not let you put one through the body of another without a warning.
Here is a problem. I have pictures.
First you see a metal sheet that is the result of cutting away 3 square areas.
Looks good here.
However, things are not really good because I still have ghosts of the original outline.
I see this, below, when I highlight, in the browser, the component that was cut away.
So, is it there? Is it not there?
The cutaway bodies that I used were rectangles that overlapped the edges by a 1 inch, but the lines are still there.
See, to me, a programmer, this looks like a program bug. I might be wrong. It could be me. You tell me.
Here is a angled view. You can see more here. The first photo was from the top.
This view is from an angle.
I cut this material away with a neg cut extrusion that overlapped the sides of the material by 1".
There should be no remains left there. Why is there a blank area between the leftover remains and the plate body?
Something is wrong here.
