Is there a preference to turn off the last modified value when press/pulling?
JFKANSAS
JFKANSAS
In previous releases this wasn't a problem, and it seems like I selected a preference at one point and shouldn't have, now I can't find it.
It is very aggravating to have the part be deformed because the measurement dialouge prefills with the last value used. When I press pull a counter bore or other feature I want to know it's present size without having to measure first. This is how the program used to work.
NicolasXu
Hi JFKANSAS,
It’s probably because the Offset Type in Press/Pull dialog was set to “New Offset” somehow. Changing it back to “Automatic” would give the expected result. Is it the case?
Best Regards,
Nicolas Xu
Sr. SQA Eng.
Fusion 360 Quality Assurance Team
Autodesk, Inc.
JFKANSAS
My Press/Pull or Offset Faces doesn't have that setting. Are you using the same version?
NicolasXu
Hi JFKANSAS,
I was using the latest release build and captured the screenshot in the parametric modeling environment.
Your question remind me that you may talk about the direct modeling. I tried the Press/Pull in direct modeling, but not able to reproduce the problem. Could you capture some screenshots or screencast to show more details so we can take a deeper look?
Nicolas Xu
Sr. SQA Eng.
Autodesk, Inc.
