Is there a list of what are known bugs in the last release?
burnandreturn
burnandreturn
It would be a very big help to a lot of us if there would be a thread with a list of gotcha's for this last release.  Then we would know if it is our lack of understanding and executing correctly or if the program is at fault.  I for one have spent a lot of time trying to accomplish a couple of things only to find out it was a bug.
Please post a list of known problems and what works and doesn't work.  Bitte!
Keqing posted this a few days ago:
http://forums.autodesk.com/t5/design-and-documentation/fusion-360-readme/td-p/4311780
Spoiler
Customer Issues Addressed In This Release
  • On a MAC Fusion associates itself to other CAD file formats.
  • CER bucket 25800141: Fusion fails when write upload file info too long.
  • Split Faces results are not stable.
  • Curvature comb doesn't update in undo workflow.
  • Corrupt after update.
  • The spline is not symmetry when it should be.
  • Fully constrained checking cases.
  • Sketch solve requires multiple updates to be visually correct
  • Sketch Solve: linear aligned dimension creates false over constrain
  • Sketch Solve : Arc angle causes over constrained status
  • Bad solving result of parallel constraint between 2 lines
  • Unexpected dragging result
  • False over-constrained warning caused by fully-constraint checking
  • Fully constrained checking problem
  • False over constrain when edit the dimension in this case
  • Restructering components crashes into joints
  • Regress: Profile selection is lost during feature edit
  • Sculpt faces unselectable after editing
  • Falsely over-constrained warning when changing dimension
  • Falsely over-constrained state when changing dimension
  • Fusion is unresponsive for a long time when changing parameters
  • Inappropriate selection of sketch profile
  • CER Bucket 24246161: Crash on material drag-drop on body
