Fillet Hell
Fillet Hell
Message 1 of 9
Fillet Hell
A so-called "friend" of mine asked me take a look at this problem as he couldn't do it.  I'm struggling too, but I'm sure there must be an expert out there who can come up with a solution?  The attached file is a representation of the final design since he could not share his client's model with me.  The brief is to add 5mm fillets to the concave edges (2 off) and 3mm rounds to the convex edges (5 off) which all meet at one vertex.  I did manage to get it to work by adding them as selection sets in one fillet feature but the resultant surface at the vertex is not what he is after.  Any help or guidance would be greatly appreciated!
Replies (8)
Message 2 of 9
jeff_strater
What is the desired result here?
Putting these all in one feature results in this:
Adding the concave fillets first, and the convex fillets second results in this:
Hope this helps.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
Message 3 of 9
Hi Jeff,
Thanks for the quick reply!  The second version looks close, but it looks like there are some non-tangent edges there?  What order did you add the fillets?
NC
Message 4 of 9
jeff_strater
I did the 5mm concave fillets first, then added the 3mm convex edges.  Yes, that does result in a handful of non-tangent edges:
I have been unable to get other results that seem better to me.
Jeff
Jeff Strater
Message 5 of 9
sanjay_jayabal
I am not sure this is any better, but for what it's worth.
best regards,
Sanjay Jayabal.
Message 6 of 9
schneik-adsk
How does this look compared to what you want?
Kevin Schneider
Message 7 of 9
Sanjay - yours looks right to me - how did you do it?
Message 8 of 9
sanjay_jayabal
Below are my steps.
STEP 1: 5mm fillets
STEP 2: 3mm fillets
STEP 3: fillet the non-tangent edge between 5mm and 3 mm fillets shown in the red circle below (fillet value = 3mm)
STEP 4: fillet the non-tangent edge between the 3mm fillets shown in the red circle below (fillet value = 3mm)
best regards,
Sanjay Jayabal.
Message 9 of 9
San_Escobar
Just my opnion.
If this solved your issue please mark this posting "Accept as Solution". Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Happy
