Is text available in the free personal use only version?
Hi (and thanks in advance for your help)
I am a total novice to 3d modelling (reasonably experienced with 2d Adobe CC).  I am trying to add text to my project but I cannot get it to appear as an option under the Sketch drop-down menu as per the various you-tube tutorial videos.  Does the "personal use" free version contain this tool? If not what else is missing?
thanks again
g-andresen
1. start sketch > Create > TEXT
günther
Hi Gunther
Thanks for taking the time to reply.
Unfortunately the option that you have highlighted does not appear on my screen (only shows 4 options, SOLID, SURFACE, SHEET METAL then TOOLS) so I'd say the 'Personal - Not for commercial use' version must be a cut-down version.  Seems a bit odd though to block something as basic as text.
thanks anyway
best regards
Caz
(My PC is new and easily capable of running the software so I don't think that would be an issue)
g-andresen
there's nothing blocked.
Text is only available in active sketch mode, like all other sketch tools.
günther
Just thought I should update you...
You were right (of course!)
With your encouragement I kept trying and eventually realised that I hadn't been properly activating the sketch mode.  I also needed to left click on the drawing board (not just click on the menu dropdown)
All now works as it should.
Thanks again
